-Oscar-
Aug 24, 2020Tutor
Orbi RBR20 frequently dropping connection
Hi, My Orbi RBR20 is getting frequent dropouts where all connected devices looses connection. The wifi can't be "seen" for aprox 2 minutes and then it comes back, wired connections loose access t...
-Oscar-
Aug 24, 2020Tutor
FURRYe38 Both suggestions were already tried. The satellite is not in use at all and setting manual channels doesn't have any effect.
Mstrbig I will try to MU-MIMO enabled, thanks
Aug 24, 2020Guru - Experienced User
OK, just checking.
As last resort, try a factory reset and setup from scratch if this hasn't been done since last FW update.
-Oscar- wrote:FURRYe38 Both suggestions were already tried. The satellite is not in use at all and setting manual channels doesn't have any effect.
