orbiRBR20user
Apr 16, 2020Aspirant
Orbi RBR20 going offline
My RBR20 keeps going offline all the time. The orbi is connected to homebroadband mobile router. The orbi has a different SSiD from the ISP router because i had problems when making them the same. ...
Apr 16, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
orbiRBR20user
Thank you for the reply even though I must admit not understanding everything, since im a real pleb when it comes to networking and english isnt my naitive language. The ISP router is a huawei b818, my isp coustumer service said that it was in bridgemode as a standard but i have a suspicion he wouldnt know the up and down of a router.
- FURRYe38Apr 16, 2020Guru - Experienced User
You can check the status of the RBR and see if the modems is really bridged by logging into the RBRs web page at 192.168.1.1 in a web browser and navigate to Advanced tab. Look at the Internet Port section and find IP Address. If the modem is bridged, it should appear with two first and second set of numbers like this: ##.##.###.###. IF you see this similar number format. then the modem is bridge. If you see a 10 or 172 or a 192 address here, then the modem is not bridged.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- orbiRBR20userApr 16, 2020Aspirant
It says unknown on the IP
I belive the house is about 250squaremeters but dont think satteites are to fare apart since the backhaul on both is green in the app.
There isnt a lot of neighbours close.
Not 100% sure how to turn of frequencies (do you mean on the huawei or the orbi?) but would that even make a difference since the orbi router is connected to the modem/huawei router with ethernet?
If unknown then there is something going on between the RBR and modem.
Power OFF both modem and RBR for 1 minute. Power on the ISP modem first and let it sync. Then power ON the RBR. After its back to ready, check the IP address again on the RBR.
Changing channels would be on the RBRs web page using a web browser.
