OrelavJ
May 27, 2020Follower
Orbi RBR20 Help - no internet connection
I've spent sevral frustrating hours now trying to set-up my new Orbi RBR20. I followed the instructions in the Orbi app and even tried them on Apple and Samsung devices but I still end up with the same problem - NO internet connection!!. I used the Advance Setup option and chose PPPoE, used the username and password provided by my ISP but no joy. I am sure there is internet connection as I immediately get it once I switch to using my old router so I must be missing something simple here. I will appreciate any help and advise. Thanks in advance
1 Reply
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? IF so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
