Ohmedic88
Dec 11, 2019Follower
Orbi RBR20 how to use with RBR50 for kids room
Idiot purchase. Im in the Dog House. My wife says we can no longer stream in the master bedroom. My son needed a wired connection for his computer so I moved my satelite to his room so he could have internet. His room is not far from the RBR50 router. Could I link the RBR20 via cable to his room for him to use? would the RBR20 be any benifit or should I just run a cable to his computer and direct line it to the RBR50?
Not sure if I can return this router (Amazon used purchase) and really don't want to spend a small fortune for a brand new satelite to get better coverage in the masterbedroom.
Would appreciate any suggestions that is not a budget breaker.
Eric
You can configure the RBR20 for AP mode and wire connect it to the main RBR50. It would be working as a separate Wifi SSID name. Would need to use channels on 2.4 and 5Ghz farthest away from what the RBR50 uses.
The RBR20 can't be used like a satellite.
Ohmedic88 wrote:Idiot purchase. Im in the Dog House. My wife says we can no longer stream in the master bedroom. My son needed a wired connection for his computer so I moved my satelite to his room so he could have internet. His room is not far from the RBR50 router. Could I link the RBR20 via cable to his room for him to use? would the RBR20 be any benifit or should I just run a cable to his computer and direct line it to the RBR50?
Eric
If the device in the master bedroom has Ethernet then I'd look at Powerline Ethernet. Uses the mains circuit to connect you to the router. Great for streaming. Easier to set up and manage than wifi, and less prone to interference
