Surffa's avatar
Surffa
Apprentice
Jul 12, 2019
Orbi RBR20 IGMP proxy behavior
Hi
I've been now debugging my IPTV device problems on Orbi for quite some time, with couple of past firmware versions without any clear difference.
Now how it seems to me, is that the IGMP proxy doesn't somehow behave properly. No matter what the setting is, Auto, or IGMPv3, the router seems to fall back to IGMPv2 when certain IGMPv2 speaking devices are turned on and connected to network.
Honestly, I don't know the RFC that well, maybe it is desired functionality, but somehow I'd expect the "IGMPv3" setting to stay in the v3 and never fall back to v2 in any case.
Additionally, I seem to have multiple IGMPv2 devices, but not all of them trigger the Orbi to fall back from v3 to v2. Especially it seems that certain Print Services on my HP Laser multipurpose device immediately cause the Orbi to fall back to v2. I managed to disable a few of them, but sooner or later the Orbi will still fall back to v2 and that I haven't been able to identify anymore, as it's so random.
Anyway, does someone know the IGMP RFCs that well, or the Orbi implementation to explain, why IGMPv3 setting on Orbi doesn't force the router to stay in IGMPv3? Is that really expected? Auto probably will fall back if needed, but is the plain IGMPv3 supposed to do that as well?
Thanks.
  • FURRYe38's avatar
    What happens if you disable IGMP on the RBR?
    Something you might contact NG support and and have them review this...
    • Surffa's avatar
      Surffa
      Apprentice
      Disabling IGMP seems to work as I would expect. Membership queries stop coming and Multicast traffic stops pretty much immediately.
      Just for notion. I'm running a real packet capture to do the Diagnosis, so I feel fairly accurate with my analysis so far..
      But all right, let me contact the support directly. I have a feeling that IGMPv3 setting is not quite working..
      • Surffa's avatar
        Surffa
        Apprentice
        Or probably I don't. My device is long past the complimentary support period and I'm not willing to pay anything for this.
        I really can't figure out how to contact support or file potential bug reports. Hmh. Weird policy if you ask me..
