Jmuller94's avatar
Jmuller94
Follower
Mar 20, 2020
Orbi rbr20 inconsistent WiFi speed
For some reason my WiFi is so inconsistent... I restarted my WiFi and modem and was getting 100+ download speed and now all of a sudden maybe an hour later I’m getting less that 30 download... someone please help because this is ridiculous!
1 Reply
  • FURRYe38's avatar
