MarkD1944
Apr 25, 2022Aspirant
Orbi RBR20 incorrect physical location
We recently moved and took our Orbi RBR20 with us. In Google Maps it indicated the current location as my previous home address. I changed the MAC address from 'Default' to 'Computer'. After reboo...
MarkD1944
I temp swapped out the Orbi with my sister's old router, and it worked perfectly. It's something in my Orbi.
CrimpOn
Apr 25, 2022Guru - Experienced User
Does the sister's old WiFi system have the same SSID and MAC address as the Orbi?
I have dumped the entire configuration file from my Orbi and there is no street address in it.
- MarkD1944May 03, 2022Aspirant
I'm not sure what the MAC and SSID addresses are for her router, and I understnnd that there is no physical address in the router. But, something in either the MAC or SSID is teling me that I am still at my old house
- CrimpOnMay 03, 2022Guru - Experienced User
What sort of device is running Google Maps?
It's not just Google Maps on my PC but also on Waze, and also similar apps on my wife's Mac using Safari.
Anything that depends on WiFi seems to point to the incorrect location.I most likely will have to factory reset the device and set it up again.
