HenryFitzgerald
Jul 15, 2019Aspirant
Orbi RBR20 internet speed lower than expected
I have a gigabit internet plan with my ISP (Actual max speeds: 950 Mbs download, 500 Mbs upload). When I connect my PC to my ONT directly via a cat. 6 ethernet cable, I enjoy the previously mentioned ...
Jul 16, 2019Guru - Experienced User
There a router at the ONT by chance? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #3 and see what the speeds are...
HenryFitzgerald
Jul 16, 2019Aspirant
The ONT has no wireless router.
Entering AP mode increased speeds to 600 download and 500 upload (as reported by the orbi app); an improvement, but still slower than I would expect.
- FURRYe38Jul 17, 2019Guru - Experienced User
You maybe seeing what I'm seeing on the 50 series:
