HenryFitzgerald
Jul 14, 2019Aspirant
Orbi RBR20 internet speed lower than expected
I have a gigabit internet plan with my ISP (Actual max speeds: 950 Mbs download, 500 Mbs upload). When I connect my PC to my ONT directly via a cat. 6 ethernet cable, I enjoy the previously mentioned ...
Liquidcore
Feb 29, 2020Star
Hey Henry,
I am with 2degrees and have the same issue - refer to this thread: https://community.netgear.com/t5/Orbi/RBR50-unable-to-handle-gigabit-connection/td-p/1825126
However it seems like MyRepublic uses DHCP instead of PPPoE which should be less resource intensive. Regardless, it sounds like the Orbi doesn't seem to powerful enough to route at gigabit speeds. If you take a look at the comparison table SW posted on the second page of that thread, it looks like NG recommends the AX series for gigabit services.
When you put the Orbi into AP mode, what router are you using? When I use my Orbi in AP mode with the 2D supplied Fritzbox as a router, I can attain the advertised speeds. Is it possible that in AP mode, the router you are using is not giving you gigabit speed either?
Long story short, the Orbi doesn't seem powerful enough to accommodate
