HenryFitzgerald
Jul 14, 2019Aspirant
Orbi RBR20 internet speed lower than expected
I have a gigabit internet plan with my ISP (Actual max speeds: 950 Mbs download, 500 Mbs upload). When I connect my PC to my ONT directly via a cat. 6 ethernet cable, I enjoy the previously mentioned ...
Bleh5
Apr 01, 2020Aspirant
AT&T/Arris BGW210
Apr 01, 2020Guru - Experienced User
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would suggest trying option #3 first...
Bleh5 wrote:AT&T/Arris BGW210
- Bleh5Apr 01, 2020Aspirant
It is NOT a double NAT situation. Modem is already configured for IP-Pass-Through with all radios turned off; Orbi is in router mode.
- FURRYe38Apr 01, 2020Guru - Experienced User
Been posts about users with this model modem not getting good speeds with external routers connected.
You might try the RBR in AP mode and then disable the IP Pass thru on the modem. Just run the RBR in AP mode behind the ISP modem.
