HenryFitzgerald
Jul 15, 2019Aspirant
Orbi RBR20 internet speed lower than expected
I have a gigabit internet plan with my ISP (Actual max speeds: 950 Mbs download, 500 Mbs upload). When I connect my PC to my ONT directly via a cat. 6 ethernet cable, I enjoy the previously mentioned ...
Apr 01, 2020Guru - Experienced User
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would suggest trying option #3 first...
Bleh5 wrote:AT&T/Arris BGW210
Bleh5
Apr 01, 2020Aspirant
It is NOT a double NAT situation. Modem is already configured for IP-Pass-Through with all radios turned off; Orbi is in router mode.
