HenryFitzgerald
Jul 14, 2019Aspirant
Orbi RBR20 internet speed lower than expected
I have a gigabit internet plan with my ISP (Actual max speeds: 950 Mbs download, 500 Mbs upload). When I connect my PC to my ONT directly via a cat. 6 ethernet cable, I enjoy the previously mentioned ...
Merilious
Apr 03, 2020Aspirant
Have had this same issue since I bought my RBR20 for over a year now
- ATT Modem/Router with Gigabit speed package
- ManufacturerModel Number: ARRIS BGW210-700
- RBR20 Router Firmware Version: V2.3.5.26
- Passthrough on ATT Modem/Router enabled and working
- RBR20 in Router mode using passthroughed IP
- LAN on ATT ONT port is full gigabit speeds confirmed on multiple laptops
- Speedtest on RBR20 admin portal gets around 500-600 download | 900+ upload
- Speedtest connected to LAN of RBR20 averages around 400mbps download
- Speedtest connected to Wifi of RBR20 averages around 400mbps download
- Returned ATT Modem/Router to defaults and confirmed full Gigabit speeds on any port on that device.
Apr 03, 2020Guru - Experienced User
What happens if you configure the RBR system for AP mode, disable IP Pass thru on the modem for the RBR?
Merilious wrote:Have had this same issue since I bought my RBR20 for over a year now
