HenryFitzgerald
Jul 14, 2019Aspirant
Orbi RBR20 internet speed lower than expected
I have a gigabit internet plan with my ISP (Actual max speeds: 950 Mbs download, 500 Mbs upload). When I connect my PC to my ONT directly via a cat. 6 ethernet cable, I enjoy the previously mentioned ...
Apr 17, 2020Guru - Experienced User
Possible that the 20 series doesnt' support near 900mpbs. Looked thru the thread, no body as returned anything faster than 500-600Mpbs.
doublepeak
Apr 17, 2020Aspirant
That would be quite surprising, given the fact that gigabit hub/router speed has been around for so many years.
I do see the other thread mentioned RBR50 had the similar issue solved after a firmware upgrade. I have strong reason to believe this is mostly a firmware issue.
FURRYe38 wrote:Possible that the 20 series doesnt' support near 900mpbs. Looked thru the thread, no body as returned anything faster than 500-600Mpbs.
- FURRYe38Apr 17, 2020Guru - Experienced User
Yes 1000Mbps has been around for many years. On the WAN and LAN ports. This is a connect rate only, not thruput speed which differs. However this doesn't mean the WAN to LAN speeds will be supported fully. A few factors will inpact this. CPU and handling of the WAN to LAN speeds and if Cut-Thru or HW NAT accelleration is included in the HW and FW to help support seeing anything near 900Mpbs on the WAN to LAN speed with a wired PC.
I have several current 1000Mpbs supporing routers, on the WAN and LAN Ports. they don't support anything near 900Mpbs on the WAN to LAN, just not enough CPU support or no HW NAT accelleration was buit in.
Something to contact NG support about and ask about it.
- doublepeakApr 17, 2020Aspirant
Thanks. I just went through the support page of netgeat. They ask to pay for Premium Support as my product was bought 2 years ago. Hmm.
I thought you are a moderator. :smileyhappy: Thanks. Dont know how to contact a real one.
We are co users and voluteers here. Just select on the tagged name and it will open there profile. You can send them a PM there.
