razz2525
Oct 21, 2019Aspirant
Orbi RBR20 iOS dropping wifi connection issue (only iPads and iPhones)
I have just added a 2nd satellite to my configuration this morning and still my iPhone X keeps disconnecting from WiFi. I realize that I'm on cellular yet again. It drops several times an hour, an...
Oct 21, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
There is newer FW available for the 5 series Orbi:
