razz2525
Oct 21, 2019Aspirant
Orbi RBR20 iOS dropping wifi connection issue (only iPads and iPhones)
I have just added a 2nd satellite to my configuration this morning and still my iPhone X keeps disconnecting from WiFi. I realize that I'm on cellular yet again. It drops several times an hour, an...
razz2525
I honestly do not know. I'd have to call Frontier. There is no modem in the house. Frontier brought a router that worked horribly. I replaced that with the Orbi router which connected to a pre-existing ethernet port that connects to a small box installed in my garage (that has no mfr or model # on it). It's a Verizon box. I have only internet service, no cable.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
The new RBS satellite is literally 6 feet from the router. The 2nd plug-in satellite (RBW30) has has a majority of connected devices to it is probably 25-30 feet away but it's around the corner from the router's location.
Channel 1 and 48. Wifi neighbors are 6.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Ok I recently installed Armor but the wifi connections were dropping prior to that so Armor doesn't seem to have affected anything. What's recommended for keeping wifi connections secure then? I will disable Daisy Chain. Fast roaming is disabled. Still don't know where this setting is for 40Mhz only which I mentioned in my original post. I only see a checkbox to disable coexistence. There is no option for 40Mhz only in Basic or Advanced wireless setup. If someone could tell me exactly where this is in the menu, I can try it.
No I have not reset anything since I updated the second satellite's firmware this morning. I simply rebooted the router and all the satellites and added daisy chaining which I will now disable.
Oct 21, 2019Guru - Experienced User
"The new RBS satellite is literally 6 feet from the router." This is toooo close. 30 feet is beginning distance.
Unchecking the check box for 20/40Mhz coexistence sets 40Mhz only.
I would factory reset the RBS first and re-add it to the RBR.
A factory reset of the RBR maybe needed as a last resort.
