charleyp1
Sep 22, 2020Star
Orbi RBR20 issues with Arris TG1682G Modem/Router for Xfinity.
Alright, yet another XFiniti issue post! Like many, I am having issues getting my mother's RBR20 to connect to the internet with the Xfinity Arris TG1682G Modem/Router. I have enabled Bridge mode...
- Sep 22, 2020
Please make sure of the following
1. The Orbi "Internet/Yellow Port" is connected by ethernet cable to Arris TG1682G.
2. No other devices are connected to Arris TG1682G ethernet ports.
3. Arris TG1682G is in bridge Mode.
4. The Orbi is in router mode and setup to obtain WAN DHCP automatically.
5. Power off both devices. Power on Arris TG1682G first and wait until LEDs show active and Internet. The power on the Orbi.
Comcast/Xfinity like most ISPs only assigns an account 2 public IP addresses and only one can be assigned to a device connected to the ethernet ports. So if you have multiple devices connected to the Arris TG1682G they may be racing for that 1 public IP address.
GMoGoody8
Sep 22, 2020Luminary
- charleyp1Sep 22, 2020Star
Okay, thanks for the advice.
1. Check!
2. I do have things plugged in there so maybe that's the issue.
3. Check!
4. Check!
5. WIll make sure I come up in that order.Thanks again.
- charleyp1Sep 27, 2020StarSo this ended up doing the trick for me. I followed these steps after resetting the Orbi to factory default. I then followed the setup using the app, NOT from a PC. I definitely think the issue was having other devices connected to the Arris modem/router.
Thanks for the assistance folks!
