giselegadot3's avatar
giselegadot3
Follower
Jul 24, 2020
Orbi rbr20 keeps disconnecting daily.
I have bought the orbi system 2 weeks ago and while the speeds are amazing and I get full coverage around my house the orbi disconnects daily . I know the issue isn’t with my modem or my isp but with the orbi router itself is there anything I can do to fix this problem.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    What have you done to determine this?
    It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
