Retired_Member
Mar 25, 2022Orbi RBR20 keeps dropping internet
I have had my Orbi RBR20 for a year and a half now and have had no issues. Beginning this week, it keeps dropping the internet. I have done multiple restarts and a couple return to factory settings...
Mar 25, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Retired_MemberMar 25, 2022
Yes, I have done a factory reset and setup from scratch a couple of times. It works for a few hours. My satellite is not on the same firmware version as the main hub, is that an issue? I will give your options a try and get back with you.
- FURRYe38Mar 25, 2022Guru - Experienced User
RBR and RBS should be same version of FW.
