Anonymous
Mar 25, 2022Orbi RBR20 keeps dropping internet
I have had my Orbi RBR20 for a year and a half now and have had no issues. Beginning this week, it keeps dropping the internet. I have done multiple restarts and a couple return to factory settings...
Anonymous
Mar 25, 2022Yes, I have done a factory reset and setup from scratch a couple of times. It works for a few hours. My satellite is not on the same firmware version as the main hub, is that an issue? I will give your options a try and get back with you.
Mar 25, 2022Guru - Experienced User
RBR and RBS should be same version of FW.
