LARRYSTIT
Oct 22, 2019Tutor
Orbi RBR20 Keeps Rebooting
I recently bought and installed an Orbi RBR20 Router with 1 satellite, and updated to newest firmware v2.3.5.26 . It was working fine for about week. But now the router is randomly rebooting itse...
fmalloy
May 31, 2020Luminary
Well, after about 25 hours with the substituted power supply, the router rebooted itself again. It's going back. I'm tired of debugging Netgear's products for them.
Houston-user
Jun 22, 2020Aspirant
Same problem for past few months. Been working fine the first year. Then after update I have needed to reboot every morning. My house is newly built too. So frustrating.
- FURRYe38Jun 22, 2020Guru - Experienced User
Houston-user wrote:
Same problem for past few months. Been working fine the first year. Then after update I have needed to reboot every morning. My house is newly built too. So frustrating. - fmalloyJun 24, 2020Luminary
Houston-user wrote:
Same problem for past few months. Been working fine the first year. Then after update I have needed to reboot every morning. My house is newly built too. So frustrating.Are you rebooting it, or is it rebooting itself? If it's the former, that is a different issue and a different thread.
- FURRYe38Jun 24, 2020Guru - Experienced User
So what happene with yours? You got a new unit?
fmalloy wrote:Are you rebooting it, or is it rebooting itself? If it's the former, that is a different issue and a different thread.
FURRYe38 wrote:So what happene with yours? You got a new unit?
Yes, they sent me a replacement RBR20 and it's been rock solid so far - uptime about 17 days now. I haven't had to reboot it either.
Routers don't (or shouldn't) spontaneously reboot themselves no matter what your configuration is.
