killah
Apr 07, 2021Aspirant
Orbi RBR20 Latency Spikes
Hello. I bought the Orbi RBR20 Mesh router a couple months ago. It was working perfectley fine with no latency spikes, especially in FPS games or games in general. But now I have latency spikes that ...
CrimpOn
Apr 07, 2021Guru - Experienced User
It would be helpful to know which Orbi unit the gaming device connects to. (router or satellite). If to a satellite, is it possible to temporarily relocate to the router? Is the device connected via ethernet cable or WiFi? (All of those WiFi parameters have nothing to do with an ethernet connection.) I would tend to think that beamforming and MU-MIMO would be better left on if the gaming device supports those standards.
It is important to determine if the problem is local to the Orbi network, or is in the Internet connection.
200 sounds like a "big number". From my perspective, 0.2 seconds seems "pretty fast in human terms." How is this ping being reported? (in the game software or through some other tool?)
killah
It is connected to the router via WiFi on the same floor, few rooms across. I test my ping in FPS games, where having a constant stable connection is a necessity, otherwise during the moments your ping spikes you're useless and essentially frozen in place, or moving aimlessley. 200 is way too much it is often higher then that tbh and last for a few seconds.
- CrimpOnApr 07, 2021Guru - Experienced User
Thanks for the details. Sound like WiFi might be relevant, but not the backhaul link between satellites and router.
My next step would be to confirm whether the issue is "my network" or "the internet". There are a bunch of ways to test this, including
- Using a computer wired directly to the router to capture a sequence of pings.
This would focus attention on the WiFi connection.
If the wired computer has no latency issue, then there is an issue with the WiFi connection. - Opening a telnet session on the Orbi router and capturing a sequence of pings.
Are you comfortable with using telnet to access the Orbi router?
(telnet access is enabled on the Orbi debug page http://orbilogin.net/debug.htm )
Log in with the Orbi web interface credentials and type the command:
ping (someplace)
If you know where the game servers are, I would compare pinging them to pinging one of the major DNS servers,
such as dns.google.com or one.one.one.one.
If this test shows the latency problem, the issue is definitely the internet. - Disconnecting the Orbi from the modem and attaching the gaming computer directly to the modem.
(This is most likely impractical for various reasons.)
You probably already know all this, so I may not be contributing much toward solving the problem.
