funkright
Mar 25, 2019Follower
Orbi RBR20 loses customized networks settings
just in the last week, when the power goes out and comes back on the orbi resets itself completely to it's initial setup parameters and loses all the individual network settings.
any ideas on what's going on?
- Chuck_MMentor
I would definitely send it back... Nothing folks here can do to help that issue.
What FW is currently loaded?
Duplicated here:
every time power goes out orb rbr20 resets complet... - NETGEAR Communities
Similar discussion here:
RBR20 factory reset on reboot - NETGEAR Communities
