sjayt
Mar 29, 2019Guide
Orbi RBR20 Losing Configuration
About once a month, for the last three months, including this morning, I lose my internet connection on all devices. It's working one day, and during the night, it goes out (I'm woken by the lights o...
- Apr 29, 2019
OP here.
This weekend I took the advice of this thread and things I had learned, and have resolved the issue.
1) I didn't use the mobile app. I used an ethernet connected PC, and using Firefox, I connected to orbilogin.com. I had wasted lots of time at the beginning of this trying to use Chrome - which refuses to login correctly, and had to find in a forum that Chrome doesn't work. Would be nice if NG would fix that BUG.
2) I downloaded both of the new .48 firmware zip files (one for the Satellites, one for the router) and extracted the .img files).
3) I installed the satellite firmware updates first. Tedious doing three separate installs, but no problems.
4) I installed the router firmware update. No problems. I downloaded a backup config after all the updates for safekeeping.
After restarting everything, it all works. No issues at all. In fact I'm getting better connection on one of the daisy-chained satellites than before the update.
I'm ready to call this case closed. Thanks all.
Mar 29, 2019Guru - Experienced User
Try a FW update to v44 if you see it in the auto update on the routers web page. If thats not available, update to v28 which the files are available for download on NG support page. Factor reset after updating and setup from scratch.
Phardy wrote:
My RBR20 repeatedly loses all my WiFi configuration settings. Worked perfectly for months, now, as of last few days, I can save the settings, but rebooting the router causes the router WiFi settings to default to the original settings.
My router is the RBR20 with 1 satellite.
Firmware version is 2.2.1.210
Steve_Hil
Mar 29, 2019Tutor
I recently started having the same issue with an RBK20W kit (RBR20 Router + RBW30 Satellite).
The units had run great for several months, but then on 3/16, and again on 3/26, it tossed out the config and reset to defaults.
It also just happened again, tonight - 3/29.
I don't recall what firmware was on it, out of the box, but it had auto-updated to V2.2.1.210, a few months back.
The Orbi itself, while configured, will not see any new firmware available, so my next step is to manually update it, and get off V2.2.1.210 firmware.
As an earlier response commented, I'm not sure how/where the OP got the .44 firmware.
On the D/L pages, the available firmware is:
https://www.netgear.com/support/product/RBR20.aspx#download - RBR20 Firmware Version 2.3.0.28 Download File size: 28.4 MB
https://www.netgear.com/support/product/RBW30.aspx#download - RBW30 Firmware Version 2.3.0.4 Download File size: 18.5 MB
The devices are not in my home, but a friend's condo. I won't be able to report on any results until I'm there, tomorrow.
Other than a possible firmware issue, the only other long-shot idea I have at the moment, is to plug the base router into a better quality surge protector, rather than the cheap power-strip it's in, now. A good APC unit will provide power conditioning, as well as surge protection. It's not common, but I have seen small surges blow out saved device configs.
The router is plugged into a VZW FIOS small indoor ONT - Image @ https://bit.ly/2uzgtkv - whilch I'll also be plugging into the APC.
Unfortunately.. Orbi, like most home/SoHo routers, is utterly useless at keeping quality logs, has zero SNMP tools, and since this issue causes a full reset, any on-unit logs, are wiped out.
So, it's a bit of a crap-shoot.
- ekhalilMar 29, 2019Master
The router should not reset itself to default settings.
Likely, you have a poor password and someone is just playing with you! Please make sure to have a stronger admin password.
If I check my Logs, I see hundreds of remote login trials daily.
- PhardyMar 30, 2019GuideThanks for the feedback. I totally agree, the router should not reset to default settings on its own. It only happens when there is a loss of power or if I reboot the Orbi. I had a strong password, and have taken the precaution of changing it and also enabled 2 layer authentication- but the router still continues to lose its settings on reboot and several devices are having issues connecting to the internet. I’ve been working on this problem strictly through the app and remotely as I’ve been out or town. Now that I’m back, I’m going to see if a factory reset fixes this issue, if not, then I’m going to manually update the firmware (currently at 2.2.1.210) - Netgear support shows a more recent version is available. (2.3.1.44), that for some reason is being auto updated. If this doesn’t work, not sure what I’ll do next. This has been a great system since I installed it, except for this issue that cropped up in the last few days.
- sjaytApr 01, 2019Guide
OP here.
The pw is NOT the issue, it's long and secure and unique.
All of the consequent replies to my post ignore the fact that I'm dealing with the .44 firmware, and that's the version that loses all configuration settings once it's rebooted.
I'm growing more certain that this is a firmware bug, that is not yet resolved in the .44 version.
- FURRYe38Apr 01, 2019Guru - Experienced User
I don't believe it's a FW bug as others have had good experiences with v44.
One mentioned doing the 30-30-30 reset method, then doing a full re-load of the v44 FW using a wired PC and IE11 or FF browser, factory reset once more then setup from scratch and after it's all setup, do a Back up of the router configuration. IF this still fails and the Orbi looses configuration, then it's time to get an RMA from NG.
sjayt wrote:
OP here.
- FURRYe38Mar 30, 2019Guru - Experienced User
Besure to factory reset after upgrading FW and setup from scratch. Once all has been setup and is working. Do a BACKUP of the configuration to file for save keeping. Try a power cycle or reboot of the system to see if the configuration persists or resets back to default settings. If it does, I recommend you file a support ticket and notify NG about this issue.
Bv44 has not been offically released for download. I believe v44 is coming thru the auto update feature on the routers web page.
If you don't see it there with current FW, means you may need to update to v28 first, then v44 may appear.
https://www.netgear.com/mynetgear/registration/login.aspx
https://www.netgear.com/support/product/RBW30.aspx#download - RBW30 Firmware Version 2.3.0.4 Download File size: 18.5 MBThe devices are not in my home, but a friend's condo. I won't be able to report on any results until I'm there, tomorrow.
- cholomanMar 30, 2019TutorI have the same problem. Reset router and save config? Really? That’s the lamest resolution I have ever heard of. A router should not be loosing its config after a reboot. I reboot orbi and the custom WiFi ssid is lost along with everything else I added. This product is junk.
- PhardyMar 30, 2019GuideOk, got it fixed.
Tried a factory reset while on firmware 2.1.2.210, setup my configuration but the router continued to reset to default settings upon reboot.
Connected via 192.168.1.1, and manually upgraded the firmware to 2.3.1.44 on the satellite first, then the router. Completed my custom config. Rebooted, and everything was retained and working like it should.
Thanks to everyone for your input on this issue.
- Steve_HilMar 31, 2019Tutor
I can appreciate the 'poor password' comment, but I assure you, it is nothing that simple.
Along the way of my discoveries and testing.. hopefully it can benefit the OP or give him/her some ideas to investigate. There are no 'Red Flags' to point in any particular direction, so I'm hitting all the usual suspects, based on pure speculation and past experience. ie:
1. Bug in the router code
2. There are 2 devices on their network, I'm not 100% trusting of
3. Dirty electicity/surges from a cheap old power-strip
4. The ISP is Verizon FIOS, and they have a 2 hour limit on DHCP WAN IP assignments.
5. The Satellite is faultySo let's tackle in sequence:
With regards to the Original Poster (OP) having his RBR20 firmware v2.3.1.44 auto-update, that's surprising, as my 2.2.1.210 system cannot yet see it, and while the unit had auto-updated from the version that was installed out-of-the-box, I'm not certain it can auto-update under this version. A Manual update check fails to see new available firmware, yet it's clearly posted on the RBR20 (V2.3.0.28), and RBW30 (V2.3.0.4) support pages. So I've downloaded it and am manually updating the firmware from local device.
According to the Release Notes for both Satellite and Router, the 2.3.xx versions "Added the customer firmware pull" as a bug fix. Not the most friendly piece of info. Does that mean they broke, then fix auto-update? Whatever.. When all else fails, Update and Reboot!
---2. There are 2 devices on their network, I'm not 100% trusting of
My friends parents have 2 'Chinese TV boxes' on the network. Basically, Android streaming boxes that connect to sources to view native Chinese broadcasts.. naturally they also connect to various pirate movie sites and cable TV feeds. They also poll for UPnP, which was enabled by default on Orbi. One of those boxes had opened 2 ports, so I shut off UPnP and a device restart allowed it to resume service. Suffice to say, I'm slightly suspect of Chinese pirate streaming boxes. And I've never ever encountered a valid reason to permit UPnP on any device.. ever.
I would love to isolate these units on another VLAN or Subnet.. but that's a level of geekery that Orbi does not support, and it would just confuse the device owners and frustrate them with an overload of gadget complications.
My best option in this firmware version, is to enable Guest Networking and force these 2 boxes onto that, while restricting device visibility to other devices. In the very remote chance that one of these pirate boxes actually "hacked" into the Orbi. Doing this prevents them from having accessibility to it.
Why this isn't the default condition for all home-wifi systems, I don't know. Every device should be isolated from every other device, unless explicitly permitted.
Easy fix. Picked up a multi-outlet APC Surge Protector / Line Conditioner. Both Orbi and the FIOS ONT will be plugged into it.
---4. The ISP is Verizon FIOS, and they have a 2 hour limit on DHCP WAN IP assignments.
I have seen a few other posts, which have noted Orbi losing Internet connections - but not configs. Usually this happens when Orbi was rebooted. Could this be related to a new DHCP poll and assignment? Extreme Longshot, but I discount nothing. Unfortunately, unless I'm watching the logs at the moment a config loss happens, I cannot correlate the events. But I've also sat thru several new DHCP WAN updates, including one a few minutes ago, and the only impact was one of the streaming Android boxes, pausing while it reconnected across the new route.
But if this causes ORBI to lose configs, we return to Option 1 - Code bug.
It also annoys me, that lack of static-IP, as well as a ridiculous frequent DHCP update, that I cannot establish any Wan IP uptime checks to know exactly what time the box drops offline.
Additionally, the very 1st time I connected to VZW FIOS, my Orbi was replacing the VZW crappy router. VZW would not let me online until I cloned the WAN MAC of their router. The 1st time my Orbi lost configs, 2 weeks ago, when I rebuilt the config, I managed to get online without cloning the MAC. I assumed VZW loosened their sphincters.
Tonight, when I rebuilt it for the 3rd time.. I reset it to factory defaults, and once more, I was unable to get online until I cloned the old VZW router MAC. There was no question about it, because I had failed PING responses from the FIOS gateway router at the nearest POP.
Lastly.. I'd been using non-VZW DNS. Namely, Cloudflare and Quad9 DNS servers. In the past, VZW has been draconian about using their network. Because I had success using the Orbi WAN MAC and non-VZW DNS, I assume there is no longer an issue with that.
However, for the purpose of testing this, I'm going to keep the "permitted" WAN MAC clone and use VZW DNS.
---5. The Satellite is faulty
For the purpose of testing, I deleted and unplugged the Satellite until further notice.
So far, I've had the problem repeat itself at 10, 7 and 3 day intervals. So now we just sit back and see if it happens again.To the OP, and anyone else who ran into this issue.. no matter how stupid a suspect cause sounds.. fix it. If there's one thing a few decades in technology has proven to me.. it's that "Technology Blows". The more advanced it becomes, the easier it breaks.
I've been banging at this for most of the day, because the damned thing has given me fits after the firmware updates, including after 2 factory defaults resets. I'm really suspect of one of the Chinese Android-TV boxes now, because despite isolating it to the guest network - ie: I manually configured it to use a non-advertised guest SSID and prevented it from seeing other network devices - it STILL tried to reconnect to the main advertised SSID. I had changed the main SSID WiFi password, so it failed, but the fact that it actively tried to jump off the SSID I manually assigned to it, makes me suspect it.
With regards to resetting my WAN MAC to clone the old VZW router, and keep the VZW DHCP assigned DNS? Well.. thanks to their **bleep**ty settings, I'm seeing DOS attacks hit the router and being dropped. Never saw these when I used Quad9 or Cloudflare DNS and the Orbi WAN MAC.
For now, I'll stick with RBR20 firmware V2.3.0.28 and no Satellite, and we'll see how it goes over the next week or so.
This is not the type of troubleshooting I would expect, nor typically tolerate, from a Home WiFi system. Usually it's business gear that is this much of a PITA. I'm not really amused.
