sjayt
Mar 29, 2019Guide
Orbi RBR20 Losing Configuration
About once a month, for the last three months, including this morning, I lose my internet connection on all devices. It's working one day, and during the night, it goes out (I'm woken by the lights o...
- Apr 29, 2019
OP here.
This weekend I took the advice of this thread and things I had learned, and have resolved the issue.
1) I didn't use the mobile app. I used an ethernet connected PC, and using Firefox, I connected to orbilogin.com. I had wasted lots of time at the beginning of this trying to use Chrome - which refuses to login correctly, and had to find in a forum that Chrome doesn't work. Would be nice if NG would fix that BUG.
2) I downloaded both of the new .48 firmware zip files (one for the Satellites, one for the router) and extracted the .img files).
3) I installed the satellite firmware updates first. Tedious doing three separate installs, but no problems.
4) I installed the router firmware update. No problems. I downloaded a backup config after all the updates for safekeeping.
After restarting everything, it all works. No issues at all. In fact I'm getting better connection on one of the daisy-chained satellites than before the update.
I'm ready to call this case closed. Thanks all.
choloman
Mar 31, 2019Tutor
I have the same problem. Reset router and save config? Really? That’s the lamest resolution I have ever heard of. A router should not be loosing its config after a reboot. I reboot orbi and the custom WiFi ssid is lost along with everything else I added. This product is junk.
Mar 31, 2019Guru - Experienced User
Try manually upgrading to v44 on your system. Seems to fix this issue if done correctly.
If you can't seem to do this, then you'll to contact NG support and ask for help and information. If need be ask for an RMA:
https://www.netgear.com/mynetgear/registration/login.aspx
- cholomanApr 01, 2019Tutor
i updated my rbr and rbs to v44 and amazingly it does not loose it's config on a reboot.
