sjayt
Mar 29, 2019Guide
Orbi RBR20 Losing Configuration
About once a month, for the last three months, including this morning, I lose my internet connection on all devices. It's working one day, and during the night, it goes out (I'm woken by the lights o...
- Apr 29, 2019
OP here.
This weekend I took the advice of this thread and things I had learned, and have resolved the issue.
1) I didn't use the mobile app. I used an ethernet connected PC, and using Firefox, I connected to orbilogin.com. I had wasted lots of time at the beginning of this trying to use Chrome - which refuses to login correctly, and had to find in a forum that Chrome doesn't work. Would be nice if NG would fix that BUG.
2) I downloaded both of the new .48 firmware zip files (one for the Satellites, one for the router) and extracted the .img files).
3) I installed the satellite firmware updates first. Tedious doing three separate installs, but no problems.
4) I installed the router firmware update. No problems. I downloaded a backup config after all the updates for safekeeping.
After restarting everything, it all works. No issues at all. In fact I'm getting better connection on one of the daisy-chained satellites than before the update.
I'm ready to call this case closed. Thanks all.
Sunilnagaraj
Apr 03, 2019Aspirant
Same issue. Fresh installation of RBK20 purchased off Amazon. 1 base and 2 satellites. 2 weeks ago it didn’t show any updates but today it does for the first time. About 2 days after first installation it lost all its settings. Has repeated every day or two. Today I thought the .44 update would fix it since it finally showed up in the IOS app. It did not. Still reset again tonight. Very disappointing and eager to hear of a fix.
Apr 03, 2019Guru - Experienced User
I would download the FW files. Install using IE11 or Firefox browser.
Factory reset then setup from scratch.
Once setup fully. Do a back up of the configration to file.
Pull the power cable on the RBR for 15 seconds then plug back in. Check to see if the config has persisted or not thru the power cycle.
