sjayt
Mar 29, 2019Guide
Orbi RBR20 Losing Configuration
About once a month, for the last three months, including this morning, I lose my internet connection on all devices. It's working one day, and during the night, it goes out (I'm woken by the lights o...
- Apr 29, 2019
OP here.
This weekend I took the advice of this thread and things I had learned, and have resolved the issue.
1) I didn't use the mobile app. I used an ethernet connected PC, and using Firefox, I connected to orbilogin.com. I had wasted lots of time at the beginning of this trying to use Chrome - which refuses to login correctly, and had to find in a forum that Chrome doesn't work. Would be nice if NG would fix that BUG.
2) I downloaded both of the new .48 firmware zip files (one for the Satellites, one for the router) and extracted the .img files).
3) I installed the satellite firmware updates first. Tedious doing three separate installs, but no problems.
4) I installed the router firmware update. No problems. I downloaded a backup config after all the updates for safekeeping.
After restarting everything, it all works. No issues at all. In fact I'm getting better connection on one of the daisy-chained satellites than before the update.
I'm ready to call this case closed. Thanks all.
RadRob
Apr 15, 2019Aspirant
I second this complaint. I have been having the same issue as descrribed by the OP. Also restoring the previous config fails when trying to recover from the reset and results in yet another reset.
| Hardware Version | RBR20 |
| Firmware Version | V2.3.1.44 |
| GUI Language Version | V1.0.0.354 |
| Operation Mode | Router |
This has happened several times over the last few months. This is the first post I have been able to find that is like my issue though.
Apr 15, 2019Guru - Experienced User
You should give this a try:
seems to help others...
Hardware Version RBR20 Firmware Version V2.3.1.44 GUI Language Version V1.0.0.354 Operation Mode Router
