sjayt
Mar 29, 2019Guide
Orbi RBR20 Losing Configuration
About once a month, for the last three months, including this morning, I lose my internet connection on all devices. It's working one day, and during the night, it goes out (I'm woken by the lights o...
- Apr 29, 2019
OP here.
This weekend I took the advice of this thread and things I had learned, and have resolved the issue.
1) I didn't use the mobile app. I used an ethernet connected PC, and using Firefox, I connected to orbilogin.com. I had wasted lots of time at the beginning of this trying to use Chrome - which refuses to login correctly, and had to find in a forum that Chrome doesn't work. Would be nice if NG would fix that BUG.
2) I downloaded both of the new .48 firmware zip files (one for the Satellites, one for the router) and extracted the .img files).
3) I installed the satellite firmware updates first. Tedious doing three separate installs, but no problems.
4) I installed the router firmware update. No problems. I downloaded a backup config after all the updates for safekeeping.
After restarting everything, it all works. No issues at all. In fact I'm getting better connection on one of the daisy-chained satellites than before the update.
I'm ready to call this case closed. Thanks all.
Steve_Hil
Apr 29, 2019Tutor
CLI FTW ;-)
sjayt wrote:
Yes, did all that. Cleared cache, restarted chrome, forced reloads. Even tried incoginto mode. Chrome wouldn't connect. Firefox did.
Didn't want to waste more time debugging it.
Steve_Hil
May 04, 2019Tutor
FYI.. My Orbi reports FW 2.3.1.58 is available for the base RBR router. The Netgear Support / Download pages have no references to it, yet.
According to the Orbi itself: V2.3.1.58 Release Notes: [Bug Fix] Fixes the issue where the time zone can't sync with the satellite. [Bug Fix] Fixes issues with the guest network control using Alexa. [Bug Fix] Includes security fixes.
However, my RBR20 CLI reports:
root@RBR20:/# uptime 16:17:09 up 11 days, 8:04, 2 users, load average: 0.62, 0.55, 0.52
So I'm not updating to new FW at this time. I did experience ONE unplanned reboot under V2.3.1.48, but so far, it's remained stable. I did not lose config after that reboot.
For now, I'll consider the issue resolved.
Support has a bunch of new questions, after our last discussion, so I'll update them, and send one final copy of the latest debug logs, but with 11 days uptime, I don't expect any logs to show anything, and this overall issue appears to be resolved.
Thanks, and good luck, folks.
- Steve_HilMay 04, 2019Tutor
Some of you may find this interesting/useful.. it's a record of each update Feature/Fix info.
https://http.fw.updates1.netgear.com/rbr20/ww/stringtable.dat
[Changes]
<MSG2062>= Initial release.
<MSG2064>=[New Feature] The second release for RBR20 and RBS20 with Canada Power table.
<MSG2410>=[Bug Fix] Fixes the issue where Orbi app displays a "Router Not Setup" message and requests the user to setup their Orbi router again even though the user already completed the Orbi router installation. [Bug Fix] Fixes issues where Internet access is not available on some devices, but available on others. [Bug Fix] Fixes an issue where Satellites get disconnected from Router. [Bug Fix] Protection for the MDNS packet flood issue. [Bug Fix] Addresses an issue where websites set to unmanaged are unreachableMultiple other connectivity & RF improvement. [Known issue] When user has two or more Orbi satellites connected to Orbi router using Ethernet backhaul connection, an Orbi satellite might not connect to the Orbi router after the firmware update. A workaround solution is to reboot the Orbi router and then wait for 2-5 minutes.
<MSG2416>=[Bug Fix] Fixes issues with the Apple HomeKit connectivity. [Bug Fix] Fixes the wireless crash and reboot issue when the router is under stress. [Bug Fix] Fixes WiFi disconnection and IOT issues. [Bug Fix] Fixes an issue where devices on the Guest Network are able to see (but not connect to) some devices on the main network. [Bug Fix] Fixes an issue where device boot order caused devices connected over Ethernet Backhaul to connect wireless backhaul. [Enhancement] Updates the OpenVPN certificate from MD5 to SHA-256.
<MSG2210>=[New Feature] Support for Orbi Voice. [New Feature] Orbi Outdoor Satellite support in Europe & Australia. [New Feature] Stability & performance related bug fixes. [Bug Fix] Bug fixes for Ethernet backhaul
<MSG2328>=[New Feature] Adds customer firmware pull. [New Feature] Expands the IP reservation function from 64 clients to 253 devices. [New Feature] Adds weak admin password checking. [Bug Fix] Fixes some issues.
<MSG2344>=[Bug Fix] Fixes the firmware update issue for Japan, Australia, and Canada.
<MSG2348>=[Bug Fix] Fixes the GUI display issue when the language is set to Japanese.
<MSG2358>=[Bug Fix] Fixes the issue where the time zone can't sync with the satellite. [Bug Fix] Fixes issues with the guest network control using Alexa. [Bug Fix] Includes security fixes. - FURRYe38May 06, 2019Guru - Experienced User
Thanks for letting us know.
[Changes]
