vinyl
Oct 04, 2019Aspirant
Orbi RBR20 network slows to a crawl when uploading -- how can I fix this?
My Orbi network slows to a crawl when something is being uploaded and using all of the limited upload bandwidth. Is there anything I can do within the Orbi settings to fix this? My setup: Orbi ...
Oct 04, 2019Guru - Experienced User
Does the same thing happen if you connect the Mac directly to the RBR instead of the RBS?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
vinyl wrote:My Orbi network slows to a crawl when something is being uploaded and using all of the limited upload bandwidth. Is there anything I can do within the Orbi settings to fix this?
My setup:
- Orbi RBR20 (V2.3.5.26) with 2 satellites connected to a basic cable modem (no integrated wifi or login info I can find online)
- Theoretical internet package speed is 120 down/5 up, but it reality I get between 80-120 down and 2.5 up as tested by either the router directly or speedtest on a connected device.
- The typical bandwidth hogging uploader is a Mac doing backups
- Upload bandwidth can be limited for cloud backup service, but not for iCloud
- Mac is connected via ethernet to a satellite with green backhaul status
The experience:
- Mac starts uploading
- Other connected devices struggle to initiate downloads. E.g.:
- Speedtest fails to complete on router
- Speedtest complains of latency issues when run from separate Mac wired to the RBR20
- Pages take a long time to load on both wireless and wired devices
- Netflix will timeout autoplaying next video
- When a device finally connects, e.g. Netflix, it can play a video without stalling
We're looking into getting a better internet package with more upload bandwidth, but
a) I worry that we'll have the same problem, just on a bigger scale
b) it sucks that the Orbi (seemingly) can't better manage the network so that one device can't ruin the network for everyone else
Any help would be greatly appreciated. Thanks!
