Loubells's avatar
May 12, 2020
Orbi RBR20 no connection to internet solved
After 5 hours of trying to get the orbi going i managed to get into the router went to internet setup then went and checked the box does the internet require a login i checked yes. I then contacted my...
  • Loubells's avatar
    Loubells
    May 13, 2020
    And my ISP told me no password was needed for thg that login name. 😊
