Loubells
May 12, 2020Tutor
Orbi RBR20 no connection to internet solved
After 5 hours of trying to get the orbi going i managed to get into the router went to internet setup then went and checked the box does the internet require a login i checked yes. I then contacted my...
- May 13, 2020And my ISP told me no password was needed for thg that login name. đ
CrimpOn
May 13, 2020Guru - Experienced User
Would you mind sharing the name of the Internet Service Provider (not your secret login information)?
The explanation seems inconsistent. The text leaves the impression that you needed to have a user login, but no password, yet the screen shot has checked "no".
pastormyke
Jun 10, 2020Aspirant
fios
