Sharadteli
May 10, 2021Follower
ORBI RBR20 not connecting to PPPoE type internet
Hi, Bought New Orbi RBK20 mesh system. However, router RBR20 does not connect to PPPoE type connection. Message is invalid password. Same when connected to old standard WiFi router, works well wi...
May 10, 2021Guru - Experienced User
There any special characters in the account PW?
"invalid password" indicates it's not able to connect using this PW or its being input incorrectly.
As a suggestion, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
