JLPoehlman's avatar
JLPoehlman
Orbi RBR20 Not holding charge
Hello all,
My Orbi RBR20 is having trouble holding a charge.  I cannot tell if the 12V AC cord has issues or if the connector inside the back of the Orbi is loose.  I do know that the connection feels a little loose.  My question is whether I would need to purchase a specific replacement cord or if there is a universal cord that could work. also, if the problem is with the connector at the back of the router, what are my options?  I purchased this unit about 2 years ago and do not have extended warranty.
  • CrimpOn's avatar
    CrimpOn
    When you plug in the power cord, does the "Power LED" turn green and stay lit?
    • JLPoehlman's avatar
      JLPoehlman
      Not all the time. That’s why I’m curious if it’s the cord or the orbi
