Codybuts
Sep 04, 2019Aspirant
ORBI RBR20 please help
hi recently upgraded my internet from 120 mbps to 1gb, they come and upgraded my modem and now im having issues with the orbi kicking my modem offline and no devices working hitron CODA-4589 is ...
- Sep 08, 2019I am going to accept the solution that it was the ISP modem all along..even after swapping out the hitron coda 4589 did just not want to keep my orbi online.
With my new Arris modem I have been staying online !
Just having slight issues with orbi speeds I will open a new thread and thanks for everyone who assisted and listened to me in this topic
Codybuts
Sep 05, 2019Aspirant
10:38 pm
Codybuts
had to reboot my coda and plug the ethernet in coda to copy and paste all this stuff . from coda.
1 Thu Sep 5 22:05:48 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
2 Thu Sep 5 22:05:53 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
3 Thu Sep 5 22:06:10 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
4 Thu Sep 5 22:06:21 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
5 Thu Sep 5 22:07:53 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
6 Thu Sep 5 22:07:59 2019 74010100 6 CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
7 Thu Sep 5 22:11:04 2019 90000000 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
8 Thu Sep 5 22:11:05 2019 73040100 6 TLV-11 - unrecognized OID;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
9 Thu Sep 5 22:11:05 2019 68001102 3 Config File Rejected due to Invalid or Unexpected TLV 11;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
10 Thu Sep 5 22:11:08 2019 73050400 5 REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
11 Thu Sep 5 22:11:08 2019 82001200 5 RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
12 Thu Sep 5 22:23:20 2019 67050300 5 DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
13 Thu Sep 5 22:29:36 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
14 Thu Sep 5 22:29:36 2019 74010100 6 CM-STATUS message sent. Event Type Code: 21; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
15 Thu Sep 5 22:29:38 2019 82000200 3 No Ranging Response received - T3 time-out;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
16 Thu Sep 5 22:29:42 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
17 Thu Sep 5 22:29:43 2019 82000200 3 No Ranging Response received - T3 time-out;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
18 Thu Sep 5 22:29:51 2019 74010100 6 CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
19 Thu Sep 5 22:31:54 2019 84000500 3 SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
20 Thu Sep 5 22:32:14 2019 74010100 6 CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=f8:1d:0f:d0:d5:a0;CMTS-MAC=b0:90:7e:0f:b0:ef;CM-QOS=1.1;CM-VER=3.1;
Clear
