Codybuts
Sep 04, 2019Aspirant
ORBI RBR20 please help
hi recently upgraded my internet from 120 mbps to 1gb, they come and upgraded my modem and now im having issues with the orbi kicking my modem offline and no devices working hitron CODA-4589 is ...
- Sep 08, 2019I am going to accept the solution that it was the ISP modem all along..even after swapping out the hitron coda 4589 did just not want to keep my orbi online.
With my new Arris modem I have been staying online !
Just having slight issues with orbi speeds I will open a new thread and thanks for everyone who assisted and listened to me in this topic
Codybuts
Sep 06, 2019Aspirant
My ISP came again switched the hitron out for some other arrys box..bridging didn't work again as it uses my tv services..so they set the ISP wifi ssid and password to the same as my orbi.
Does this make any sense ?
- FURRYe38Sep 06, 2019Guru - Experienced User
What is the model# of the new modem?
Is the RBR in AP mode still? If so, you should be getting internet thru the Orbi RBR and it's wifi.
They really should have used a separate SSID name for your TV services WiFi. This may confuse you and your wireless devices and your wireless devices will connect to the ISP modems wifi instead of the Orbis wifi.
