Codybuts
Sep 04, 2019Aspirant
ORBI RBR20 please help
hi recently upgraded my internet from 120 mbps to 1gb, they come and upgraded my modem and now im having issues with the orbi kicking my modem offline and no devices working hitron CODA-4589 is ...
- Sep 08, 2019I am going to accept the solution that it was the ISP modem all along..even after swapping out the hitron coda 4589 did just not want to keep my orbi online.
With my new Arris modem I have been staying online !
Just having slight issues with orbi speeds I will open a new thread and thanks for everyone who assisted and listened to me in this topic
Codybuts
Sep 06, 2019Aspirant
My ISP came again switched the hitron out for some other arrys box..bridging didn't work again as it uses my tv services..so they set the ISP wifi ssid and password to the same as my orbi.
Does this make any sense ?
Sep 06, 2019Guru - Experienced User
What is the model# of the new modem?
Is the RBR in AP mode still? If so, you should be getting internet thru the Orbi RBR and it's wifi.
They really should have used a separate SSID name for your TV services WiFi. This may confuse you and your wireless devices and your wireless devices will connect to the ISP modems wifi instead of the Orbis wifi.
- CodybutsSep 06, 2019AspirantI will get the model number when I get back home.
I don't believe they share the same public wifi with the tv but a different wifi or something in the modem..
I'm really not sure, I will report back- FURRYe38Sep 06, 2019Guru - Experienced User
:smileyhappy:
- CodybutsSep 06, 2019AspirantHey buddy, so nothing has kicked off..I ran orbi router + 1 satellite.
Orbi router front of house basement.
Satellite 1 back of house main level.
Everything been fine 300 ish Mbps sitting outside .
Satallite 2 plugged into garage, before even with 120 Mbps I'd get 30-40. Id expect atleast 100 as it's not far from satellite 1. Right now I'm getting 10-25 Mbps.
Satellite 2 is poor
Could you help me resolve this đ.
This is a pic of satellite 2.. right on other side of wall is satellite 1 .. if I'm close to wall I get 300+ Mbps.. inside garage no good.
