Codybuts
Sep 04, 2019Aspirant
ORBI RBR20 please help
hi recently upgraded my internet from 120 mbps to 1gb, they come and upgraded my modem and now im having issues with the orbi kicking my modem offline and no devices working hitron CODA-4589 is ...
- Sep 08, 2019I am going to accept the solution that it was the ISP modem all along..even after swapping out the hitron coda 4589 did just not want to keep my orbi online.
With my new Arris modem I have been staying online !
Just having slight issues with orbi speeds I will open a new thread and thanks for everyone who assisted and listened to me in this topic
Codybuts
Sep 06, 2019Aspirant
Also like I stated my isp renamed their wifi to mine ( althout I don't think it does anything at all and I told them that , also made sure to forget it in my wifi list so I never connect to it, they also said they switched some band mode ? Idk either way I'm pretty sure I can login my router and disable their wifi and it won't change a thing, I know it's seperate from the TiVo wifi or something cause I've done it on each modem .
Codybuts
My only issue now is after sitting in my living room for half hour and check my speed it's 40 Mbps, I reload my wifi connection and it goes back to 500.. what causes this ?
