Metro32168
Dec 28, 2019Aspirant
ORBI RBR20 port 443 not opening ??
Port 443 not opening on this model. Have changed modem (isp restriction) and still not open. Have a RBR850 and port 443 works on that model. Anyone know if this model doesn’t support port? Using...
Jan 02, 2020Guru - Experienced User
Are you disabling uPnP when setting up any PF configurations?
Has a factory reset and setup from scratch been performed on the RBR?
Metro32168
Jan 02, 2020Aspirant
ORBI was a new install at separate location.
ORBI self updated firmware, change cable modem (net gear cm1100)( origanally Motorola )
The first ORBI rbr850 was fine, with all the ports opening (554,443,80) for nvr.
Was originally working when xfinity service installed. Not isp block issue. (Own modem)
Any help will be appreciated
