SonicGT
Jan 19, 2019Aspirant
Orbi RBR20, PS4 and Denon Receiver don't reconnect when coming out of sleep
I just upgraded from an old linksys route to the orbi setup.
I got everything connected but have noticed my PS4 and my Denon receiver don't seem to auto reconnect when coming out of sleep. If I go...
ekhalil
Jan 19, 2019Master
It looks to me that the issue is in the devices (PS4 and Denon) not rememberting Orbi's wifi network and credentials. If you change Orbi's SSID and wifi security and password to what was working with Lynksys then probably all will work again.
- SonicGTJan 19, 2019Aspirant
So I don't have to actually reconnect to the SSID by typing the password again, I just have to force it to reconnect by doing test internet connection. it then gets DHCP. It seems to actually be connected in some way, just doesn't retain or get an IP address or DNS until I force it to check the status of connection.
I am using the same ssid and wpa2 setting that I had with my prior router
- ekhalilJan 19, 2019Master
Yes, it seems that the PS4 is dropping wifi connection when in rest mode since it will be in a low power state, then failing to re-establish a connection as the PS4's resources are limited.
I see many people raising similar concerns in PS4 forums, please see examples below:
https://www.drivereasy.com/knowledge/fixed-ps4-not-connecting-to-wifi-after-update/
If the suggestions on those forums do not fix your problem then do you have any possibility to use wired connections to those devices, maybe using repeaters or powerline adapters?
