jandreuservera
Jul 01, 2022Tutor
ORBI RBR20 "Radar Detected" makes Wifi dropping
Hi I have a RBR20 + two RBS20 and I have experienced many wifi drops. It happens without a time o day pattern. Extracting debug information via "debug.htm" page I see the following information that ...
- Jul 10, 2022
As I see stability in the Wifi connection I think the change in Wifi channels has helped or maybe has not been any interferences in the surroundings.
I close the post.
Thanks
ekhalil
Jul 01, 2022Master
Try changing the wifi channels that you use for the 5 GHz as well as for the 2.4 GHz bands. It can be that you have disturbances from the surroundings?
jandreuservera
Jul 01, 2022Tutor
Wifi channels changed:
2.4GHz from 1 to 6
5GHz from 36 to 48
Let's wait several days to check if the wifi is stable. By the way, I see the connections between router and satelites are using 2.4GHz band:
Maybe it will make the configuration completely stable to 5GHz interferences, but at the cost of a lower performance. I would be happy with the stability even if i loose speed of transmission.
Thanks
- jandreuserveraJul 10, 2022Tutor
I close the post.
Thanks
- FURRYe38Jul 10, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
