rblades
Nov 14, 2020Initiate
Orbi RBR20 regular disconnects
Hello, I have the above Obri Router. For the past 11 months, it has worked great. Our internet service provider installed a new modem and since then every day I need to reset the Orbi (unplug, wait...
- Nov 14, 2020
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATCouple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the
Nov 14, 2020Guru - Experienced User
Couple of options,
rblades
Nov 22, 2020Initiate
Thank you! I had to call my ISP to turn off the wifi on my modem. Then after resetting the whole system we have been stable for a week. Thanks for the help!
