rblades
Nov 14, 2020Initiate
Orbi RBR20 regular disconnects
Hello, I have the above Obri Router. For the past 11 months, it has worked great. Our internet service provider installed a new modem and since then every day I need to reset the Orbi (unplug, wait...
- Nov 14, 2020
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATCouple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the
rblades
Nov 22, 2020Initiate
Thank you! I had to call my ISP to turn off the wifi on my modem. Then after resetting the whole system we have been stable for a week. Thanks for the help!
