cobra427dan
Feb 14, 2020Aspirant
Orbi RBR20 Roku Problem
Hey all, My apologies if this is a duplicate post. I thought I posted this question already, but must have never hit submit because I can't find it now. So, I recently bought an Orbi RBR20 with ...
- Feb 19, 2020
CrimpOn,
I THOUGHT I replied, but don't see my reply now, SO, the factory reset worked perfectly!
After the reset I went through the connection setup and when the "college/dorm" or "home" question popped up I selected "home" and BINGO, streaming beautifully.
I thank you and so does my son since it's in his room!
SOLVED!
cobra427dan
OK, hmmm. The problem is there is no way to ignore it because I can't get past the "college/dorm" pop up. If I just close out of the process I end up with no connection. I'm not a hardcore tech guy, but I can usually hold my own. I'm wondering if it might have something to do with the MAC addresses?
Well, the mystery continues.
Thanks for the info.
Feb 15, 2020Guru - Experienced User
You put that it works fine on the google router?
Are you running a google fiber router plus Orbi? What model google fiber box do you have the orbi connected to?
If so you either need the google fiber box in passthrough mode/modem only mode or you'd need the orbi in AP mode.
