elaine29's avatar
elaine29
Orbi RBR20 router - trouble
For the last couple of years I've been using a Orbi RBR20 router and two satellites in access point mode  - However , without making any changes, recently the wifi connection is constantly dropping out.
I've checked the wifi provider and the NF18 modem is working well.
  • However the Orbi RBR20 router "does not support 802.11AC or newer WoFi technology which limits the range and speed of its signal. An update is recommended.
Please advise how to update the Orbi RBR20 to ensure it works consistently and with max speed
Thanks in advance
Elaine
  • CrimpOn's avatar
    CrimpOn
    elaine29 wrote:
    • However the Orbi RBR20 router "does not support 802.11AC or newer WiFi technology which limits the range and speed of its signal. An update is recommended.
    This is not correct.  The RBR20 Product Data Sheet clearly states that it supports 5G WiFi, including 802.11a/b/g/n/ac (page 4)
    https://www.netgear.com/images/datasheet/orbi/RBR20.pdf
    Something has gone wrong, but this is not it.  Perhaps some more detail about how the "dropouts" manifest?  what is observed? which devices?
    • elaine29's avatar
      elaine29
      Thanks CrimpOn
      Unclear what seems to trigger wifi drop out - just that wifi is dropping out continuously: all devices lose wifi: PC, mobile phone; speakers
      Have run wifi speeds and they're all good - its just the cut outs
      I no longer love my wifi - as its stopping me work and play :(
      • CrimpOn's avatar
        CrimpOn
        Can you please confirm the firmware release on this Orbi?
  • CrimpOn's avatar
    CrimpOn
    There was probably a reason for putting the Orbi into Access Point mode. Can you share why that was done?
    Thanks in advance
    Elaine
    I. Am not sure about current firmware installed. Using Orbi mesh router onMac Mini OS 12 2 1
