dstrbd
Feb 13, 2020Tutor
ORBI RBR20 router is offline but satellite is online
The problem is ORBI RBR20 router is offline (red dot on app) but satellite is online (green dot on app). This cannot be right. I disconnected the ISP router and connected the Orbi to the Gigibit mode...
- Feb 14, 2020
Thanks. I suspect that the issue is the Nokia does not provide a "public" IP address to the Orbi, and thus the Orbi thinks it is not connected to the Internet. One clue is that the Nokia provides (4) ethernet ports and seems to be doing "router stuff". (IGMP snooping, QoS, VLAN's)
http://www.goamt.com/wp-content/uploads/2015/08/7368_ISAM_ONT_G-240G-A_AMT.pdf
When searching for information on the Nokia, I came across this post: https://www.reddit.com/r/dubai/comments/a39kc5/du_router_nokia_g240gc_login_credentials/
I understand this is all absurd because the Orbi obviously IS connected to the internet since "it works."
CrimpOn
Feb 13, 2020Guru - Experienced User
I believe the satellite "green" light means that it successfully connected to the router, not that it has internet access.
The yellow (WAN) port has to be connected to the modem for the Orbi to recognize that it has a good connection.
