red_cherries
Sep 25, 2021Tutor
Orbi RBR20 Router keeps dropping
This Orbi RBR20 was working fine. (I tried to put as much details here) Setting up the router, either the Wi-Fi name or the internet connection keeps on dropping. It's not the internet (provider)...
michaelkenward
Sep 26, 2021Guru - Experienced User
Setting up the router, either the Wi-Fi name or the internet connection keeps on dropping. It's not the internet (provider) connection issues as I tried several times switching it back to the NetComm NF4V Modem - with the modem it works fine and internet never drops out.
Is that the modem that sits in front of your RBR20? Unless you have set it to "bridge" mode, or the Orbi is an wireless access point mode, this means that you have two routers in your network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
A lot of people use an Orbi system in AP mode, especially if they have a decent router in front of it. Only you know which of your two routers provides the best features for your needs.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
red_cherries
Sep 26, 2021Tutor
Thank you michaelkenward
Yes - the Orbi is in front of me.
No - I don't use 2 routers. Either the Orbi or the Modem. I did try to have both on, but it just didn't work. So if in usage, then either one or the other.
No - didn't use Orbi for AP Mode. Just Router.
Thanks for the links too. I did try to exhaust all the possibilities that I could search in the communities and the help page. And still stuck with unstable Orbi Router.
I'll have a read again on the documentation for the hardware whilst waiting for the Netgear moderator to assist.
Thank you so much.
- michaelkenwardSep 26, 2021Guru - Experienced User
I don't understand that. What do you mean by either the Orbi or the Modem?
The Orbi is not a modem. It cannot replace the NetComm as a modem. So there will be something in front of the Orbi. If it isn't the NetComm, what is it?
If you are not using the NetComm NF4V as a modem alongside the Orbi router, you will have a different modem in front of the Orbi.
The NetComm NF4V Modem is not a simple modem. It is a modem/router. (Look at all those LAN ports on the back and the wifi LED.)
If you have this on the network AND the Orbi, then you have two routers.
This can cause the sort of problems that you describe and that are explained in the links I posted earlier.
- red_cherriesSep 30, 2021Tutor
So you mean i use the NetComm modem to connect the internet from source - then the Orbi Router is connected internet through NetComm modem? thanks
I'm not only struggling setting up the Orbi but also posting this post. Keep on giving error message saying invalid HTML but i don't have any links........... just plain text.......
- michaelkenwardSep 30, 2021Guru - Experienced User
That's the way these things usually work.
In your case, life is made complicated because your "modem" is actually a modem router. (See above.)
- FURRYe38Sep 26, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi AC (WiFi 5) products. Most of the people who watch that forum are more likely to have experience with Orbi AC and know how to work it better than those of us who follow this forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/OrbiThank you.
Thank you so much.
