SmilingEddie
Aug 01, 2020Guide
Orbi RBR20 router magenta light remains on - I want it off
This problem has only existed since moved to a wired backhaul. Everything else works fine. Its configured as an Access Point. Only the Guest SSID is appears in neighbourhood device WiFi lists, I oft...
- Aug 03, 2020
FURRYe38 wrote:So even with the RBS and this switch disconnected from the RBR does the RBR top LED remain on?
What is the mfr and model# of this switch?
Confess, I only tried connectivity that was viable, i.e, plugged-in. But since you suggested it... even when the RJ45 is removed, it still slowly pulses white. I've powered off, paused and turned it back on again. It flashed white for a while but now... the light has gone out!! Ha! Well done FURRYe38!! Thank you.
Something noticed while testing to see what price I'm paying for this, is that the icon for the SBSs had changed to a Linux device in both cases. Odd, but I can live with that. Switches are a Netgear GS105 and a TP-link TL-SG1016DE BTW.
Again, thanks so much.
Aug 02, 2020Guru - Experienced User
I've never used the LAN ports for a primary connection to the main host router. I always use the yellow LAN port for the RBRs connection to the host router or a ISP Modem always. The the LAN ports are for direct connected RBS which if used will be wired backhaul in this configuration. IF the RBS are not wire connected then the back haul will be wireless.
SmilingEddie
Aug 02, 2020Guide
Thanks. The steady magenta light has now been replaced with a blinking white one.
Apart from going back to the magenta light, is there another option here?
BTW, the satelittes are still using the wired backhaul with the router connected via the Internet/yellow socket, so thanks for that.
- FURRYe38Aug 02, 2020Guru - Experienced User
What is the mfr and model # of the host router the RBR is conencted too?
What does the status say when you log into the RBRs web page on the Basic Tab using a web browser?
- SmilingEddieAug 02, 2020Guide
The router between the LAN and the ISP Is a CISCO RV340-K9 V01 running firmware 1.0.03.18
The status of the RbR shows as GOOD.
FURRYe38 wrote:What is the mfr and model # of the host router the RBR is conencted too?
- michaelkenwardAug 03, 2020Guru - Experienced User
That is another router. Is your Orbi router in wireless access point mode?
If not you are in "double NAT" territory.
What is Double NAT? | Answer | NETGEAR Support
Some routers can adjust themselves during setup to accommodate that, but moving things around as you have may have upset it.A lot of people use an Orbi system in AP mode, especially if they have a decent router in front of it.
