SmilingEddie's avatar
Aug 01, 2020
Orbi RBR20 router magenta light remains on - I want it off
This problem has only existed since moved to a wired backhaul. Everything else works fine.  Its configured as an Access Point. Only the Guest SSID is appears in neighbourhood device WiFi lists, I oft...
  • SmilingEddie's avatar
    SmilingEddie
    Aug 03, 2020
    FURRYe38 wrote:
    So even with the RBS and this switch disconnected from the RBR does the RBR top LED remain on?
    What is the mfr and model# of this switch?
    Confess, I only tried connectivity that was viable, i.e, plugged-in. But since you suggested it... even when the RJ45 is removed, it still slowly pulses white.  I've powered off, paused and turned it back on again.  It flashed white for a while but now... the light has gone out!! Ha!  Well done FURRYe38!! Thank you.
    Something noticed while testing to see what price I'm paying for this, is that the icon for the SBSs had changed to a Linux device in both cases. Odd, but I can live with that. Switches are a Netgear GS105 and a TP-link TL-SG1016DE BTW.
    Again, thanks so much.
