kyukenmyo
Jul 16, 2020Aspirant
ORBI RBR20 Satellite Constantly Dropping Internet (With High Packet Loss)
Hi everyone! Been struggling with a high packet loss and constantly disconnecting connection between my router and satellite kit. If I turn off the satellite, the packet loss significantly improves, ...
kyukenmyo
Jul 17, 2020Aspirant
Really appreciate your help, Furry.
Check this out- I attached the pingplotter map. Lord- it seems to build up and just disconnect after a while. Packet loss is all over the place.! Wow!
I'm going to do another test with just the RBR on pingplotter and see if latency is improved.
Unfortunately, I'd say it's impossible to disconnect all the wifi devices to isolate this until everyone's out of the house. Hm...Does sound like it could be faulty. I don't have another RBS20 at the moment to try this out, but at this point I'm wondering if dropping another 100 on an RBS is worth it or if I should just upgrade to another system (orbi pro or not).
I'll do the packet loss test again with the satellite off just connected to the router to confirm. But yowzas. Do you have any idea what this graph means? Haha
Jul 17, 2020Guru - Experienced User
Interesting tests...
Besure to ping test with a wired PC directly connected to the modem with out the RBR.
- kyukenmyoJul 22, 2020Aspirant
Kind of given up so far on using the satellite. Router is almost completely fine. Some ping spikes every hour or so, but nothing unmanageable. Satellite has 30% packet loss every 3 seconds.
- FURRYe38Jul 22, 2020Guru - Experienced User
Possible faulty RBS. Something to ask NG support about.
