siaraf
Mar 18, 2019Aspirant
Orbi RBR20 setup for NBN
We've recently been connected to HFC NBN through iiNet and can't get the Orbi to work anymore.
Current setup is NBN box Arris CM8200 with Cat5 cable into the WAN port of TP link AC1600 modem/...
- Mar 19, 2019
Awesome. Glad you found the problem.
Please mark your thread as solved so others will know for future reference.
Enjoy. :smileywink:
siaraf wrote:
So I then just tried swapping which cable I was using, and it all works!
NBN box connected straight to Orbi, with different Cat5 cable, and everything synced.
Amazing and thanks for the help!!!
Chuck_M
Mar 18, 2019Mentor
Silly question probably: After reconfiguring with Orbi connected to NBN box Arris CM8200, did you perform a power-off reboot of the equipment above your Orbi and then your Orbi itself?
