siaraf
Mar 18, 2019Aspirant
Orbi RBR20 setup for NBN
We've recently been connected to HFC NBN through iiNet and can't get the Orbi to work anymore.
Current setup is NBN box Arris CM8200 with Cat5 cable into the WAN port of TP link AC1600 modem/...
- Mar 19, 2019
Awesome. Glad you found the problem.
Please mark your thread as solved so others will know for future reference.
Enjoy. :smileywink:
siaraf wrote:
So I then just tried swapping which cable I was using, and it all works!
NBN box connected straight to Orbi, with different Cat5 cable, and everything synced.
Amazing and thanks for the help!!!
Mar 18, 2019Guru - Experienced User
Remove the TP-Link router from the mix.
Current setup is NBN box Arris CM8200 with Cat5 cable into the WAN port of TP link AC1600 modem/router. This provides inadequate Wifi coverage for our house.
I have tried connecting the Orbi to the TP link AC1600 via ethernet with no luck.
I have tried direct connection of the Orbi with the Arris NBN box with no luck.
I have set the Orbi VLAN to 2, and I have tried powering down all the devices for over an hour while doing the above.
The Orbi worked perfectly until yesterday when we changed to NBN.
Any ideas much appreciated!
- FURRYe38Mar 18, 2019Guru - Experienced User
:smileywink:
- siarafMar 18, 2019Aspirant
Hi guys, I powered everything off for an hour and tried the following setup.
Arris>Cat5 cable>Orbi internet port. I used the Orbi app, and followed the steps for powering on (Arris on>connect to Orbi>power on Orbi router>power on Orbi satellite).
The Orbi transmits a wifi signal with the same name as the previous network, but shows as local connection only (ie no internet). I can't even get in their to update the Firmware.
I even tried resetting the Orbi but it still is bringing up the old wifi network name, so I'm not sure if this is where the conflict is?
Can you try seting up the Orbi with a wire connected PC?
Might swap the LAN cable between the ISP modem and Orbi. Besure to power OFF the modem first for 30 seconds then back on. THen power ON the Orbi base. Walk thru the setup wizard at orbilogin.com in a web browser.
